| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Hi everyone. I have a 200 4R transmission that was supposedly rebuilt. The output shaft has play in it. Is this normal? I have an old TH350 tranny with no play at all in the output shaft. I'm concerned the guy who built the 200-4R messed it up. Any thought on this loose output shaft? Thanks
Remember, for every mile of road, there's two miles of ditch! If you fall on your face, you're still moving forward.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Are you checking output shaft play with the yoke installed? There is a bushing in the tailpiece which the yoke rides in. This arrangement tightens up the tailshaft movement.
| | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Thanks 52Carl, I will try that and see.
