4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#1225637 07/15/2017 2:34 PM
Hi everyone. I have a 200 4R transmission that was supposedly rebuilt. The output shaft has play in it. Is this normal? I have an old TH350 tranny with no play at all in the output shaft. I'm concerned the guy who built the 200-4R messed it up. Any thought on this loose output shaft?
Remember, for every mile of road, there's two miles of ditch!
If you fall on your face, you're still moving forward.
Are you checking output shaft play with the yoke installed? There is a bushing in the tailpiece which the yoke rides in. This arrangement tightens up the tailshaft movement.
Thanks 52Carl, I will try that and see.
