8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd), 138 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
Hello, this is my first post and I'm looking forward to developing good relationships with the members.
I have a 56 GMC 100 that I bought in pretty nice shape - which is why I put "restoration" in quotes in the title - I can't take credit for what I did not do. What I am in the process of doing is correcting some of the things that were not done correctly and ultimately want to get this beautiful truck very close to original so that others can experience a little of the 50's.
As I am getting ready to remove the exhaust manifolds to repair some leaks I was wondering if the bolts that hold the fender in place should be painted the same as the truck or would they be raw when it rolled off the assembly line?
Any input on what would make this truck closer to original would be greatly appreciated.
56 GMC 100
Big Bolt Forum Moderator
welcome to the site! That is a beautiful truck! You might ask about the paint color for the fender bolts in the paint and body section, (although since you already asked here, it would be frowned upon to ask the same question in a different section!).
Mike
Nice.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Welcome to the "Bolt". Very nice truck.🛠
Thank you all so much. And thank you for the information on protocol; I will try to abide by that in the future. Hopefully someone will be able to opine on my original question and we will all be the wiser.
Chevrolet & GMC might have painted them differently.
My guess is the bolt heads that show inside the bed were painted bed color.
Welcome to the Stovebolt wave
I believe the front fenders/grille panels were painted separately and then assembled to make the front clip so all of these bolts would be natural. The 8 bolts holding the front clip to the cab/chassis would also be natural.
I also think the rear fenders were painted and then bolted onto the bed. What make me thik this is the piece of bed side that's under the fender is always the body color, so the bed sides must have been painted before the fenders were installed.
Here's a 1956 factory picture with a Chevrolet front clip being assembled...
http://www.imgrum.org/media/984897942868241686_367957858
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
That's what I suspected Mike B. And thank you for that great picture!
I find it interesting that they assembled the front clip prior to installing it to the frame. Now I wonder if they did the same thing with the ADs.
Carl,
I think it's been that way since the beginning...in the 30's they put the radiator shell on the chassis first, then the front fenders with the running boards and then the body.
Check out this 1946 assembly line film, it's a treasure trove of details. You'll see the front clip getting installed already painted and trimmed out!
I know this is cars, but the trucks came down the same line and would in theory be assembled the same way, check out this picture of a truck cab behind a '57 four door sedan, on the line!
https://s-media-cache-ak0.pinimg.co...d52fc--vintage-industrial-line-photo.jpg
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
You got you a fine looking truck!
1959 3100 Apache Fleetside
Nice!
1950 3100 5 Window
http://imgur.com/a/DAVYB
