| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 9 New Guy | | New Guy Joined: Aug 2004 Posts: 9 | I have discovered that one of my 1949 Chevy 3/4 ton window regulators has a broken main spring. I am unable to find a new or used replacement spring. Therefore, I am considering buying an aftermarket window regulator. I have read several comments about the quality of these regulators.
Question : Which vendor sells a quality window regulator?
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Buy the aftermarket unit, remove the spring and throw the rest in the scrap. Consider it an expensive spring. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | American Classic Truck Parts lists one. Item #18-781 which may be what you want.
Ed
| | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Check Jim Carters he lists a crank spring for 47 to 66 trucks. Not sure if that's what you need but would be worth a look.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
