2 members (55shaker, Peggy M), 78 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1225070 07/12/2017 12:47 AM
JFO
Offline
I have discovered that one of my 1949 Chevy 3/4 ton window regulators has a broken main spring. I am unable to find a new or used replacement spring. Therefore, I am considering buying an aftermarket window regulator. I have read several comments about the quality of these regulators.
Question : Which vendor sells a quality window regulator?
Buy the aftermarket unit, remove the spring and throw the rest in the scrap.
Consider it an expensive spring.
American Classic Truck Parts lists one. Item #18-781 which may be what you want.
Ed
Check Jim Carters he lists a crank spring for 47 to 66 trucks. Not sure if that's what you need but would be worth a look.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
