3 members (cmayna, BC59, Wickedbass), 51 guests, and 5 robots.
Topics128,086
Posts1,056,101
Members48,434
#1224881 07/11/2017 3:27 AM
1948 Chevrolet 235 Pick-up, Carter YF Carb. Question: the carburetor schematic shows a gasket that goes on top of the Insulator Plate, between the Carb (throttle body) and the insulator plate. Should there be a 2nd gasket that goes on the bottom of the insulator plate between the insulator plate and the Intake manifold? OR just the insulator plate on the manifold no gasket?
Nope don't think so, should be ok. If worried can spray some B12 at that area with motor running and see if she speeds up.
1946 1/2-Ton Chevy
Riding in the Passing Lane
I like to put a gasket on both sides of the insulator.
1972 Chevy c10 Cheyenne Super
Is it odd that the Shop Manual does not mention a gasket or the spacer/insulator?
The Master Parts Manual refers only to a gasket between spacer and carburetor.
I always use a gasket between carburetor and insulator (with the cut-out properly oriented).
I have sometimes used a gasket between spacer and manifold (if the mating surfaces were not real smooth).
I have never had a leak when I did not use a gasket between the insulator and clean/smooth insulator and intake nanifold.
Excellent, many thanks!!
