3 members (Gib70, Leo, Gray_Ghost), 66 guests, and 3 robots.
Topics128,134
Posts1,056,410
Members48,441
#1225018 07/11/2017 8:42 PM
I've got a ratty old 63 C20 I'm thinking of turning into a flat bed. While looking for some for ideas I was drawn to the duallys. I've been reading up the last couple days and have seen a variety of options to do this from swapping out the whole rear end to longer studs and a little grinding on the hub. I'm not looking for 1 ton functionality just the look. I can probably get some old steel rims for free. There's an 85 parts truck with a dually rear end for sale near by. I'm curious if anyone has an opinion on this. good, bad, or otherwise.
Here's my truck. I'm going for a bit of a rat rod shop truck look.
C20 Side View
C20 Front View
Thanks for looking.
Since your plan is to make it a flat bed there is no concern over the width. Get the dually rear end and weld on perches to fit your spring/link set up. Easy to get parts/wheels for and maybe a better ratio for drive-ability.
