0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | 1948 Chevrolet 235 Pick-up, Carter YF Carb. Question: the carburetor schematic shows a gasket that goes on top of the Insulator Plate, between the Carb (throttle body) and the insulator plate. Should there be a 2nd gasket that goes on the bottom of the insulator plate between the insulator plate and the Intake manifold? OR just the insulator plate on the manifold no gasket? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Nope don't think so, should be ok. If worried can spray some B12 at that area with motor running and see if she speeds up. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I like to put a gasket on both sides of the insulator. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is it odd that the Shop Manual does not mention a gasket or the spacer/insulator?
The Master Parts Manual refers only to a gasket between spacer and carburetor.
I always use a gasket between carburetor and insulator (with the cut-out properly oriented). I have sometimes used a gasket between spacer and manifold (if the mating surfaces were not real smooth). I have never had a leak when I did not use a gasket between the insulator and clean/smooth insulator and intake nanifold. | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | | | |
