2 members (Otto Skorzeny, 1 invisible),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I see that they offer a stainless steel hood center strip.... and I am body working the hood right now- if I remove the center strip that's on the hood now, will the hood start to separate? My strip has a fairly large gap in two places and leveling the hood is becoming a real chore with the strip installed. But I don't want the hood to separate/ buckle while I'm working on it. Anyone dealt with this? Hood
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Look at the seam on the underside of the hood. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Yes, I see that it is riveted together on the underside. I was wondering whether it was perhaps spot-welded together on the top side, under the center strip. Probably not. I'll remove the strip tomorrow to confirm. Additionally, I found a "bullnose" polished aluminum hood center strip with clips for $33 at Chev's of he 40's. Wondering if anyone has installed that one? It's a lot cheaper than going stainless...but will require regular polishing, no doubt.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Not spot welded. Riveted is OEM. All you'll see under the center strip is the joint of the two halves. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Mark, yep that's what I found. Thanks.
