4 members (Gdads51, 55shaker, Bruce 1954-4100, Hanks custodian), 101 guests, and 2 robots.
Topics128,109
Posts1,056,253
Members48,437
#1224589 07/09/2017 4:33 PM
I see that they offer a stainless steel hood center strip.... and I am body working the hood right now- if I remove the center strip that's on the hood now, will the hood start to separate? My strip has a fairly large gap in two places and leveling the hood is becoming a real chore with the strip installed. But I don't want the hood to separate/ buckle while I'm working on it. Anyone dealt with this?
Hood
~ Dave
Look at the seam on the underside of the hood.
Yes, I see that it is riveted together on the underside. I was wondering whether it was perhaps spot-welded together on the top side, under the center strip. Probably not. I'll remove the strip tomorrow to confirm. Additionally, I found a "bullnose" polished aluminum hood center strip with clips for $33 at Chev's of he 40's. Wondering if anyone has installed that one? It's a lot cheaper than going stainless...but will require regular polishing, no doubt.
~ Dave
Not spot welded. Riveted is OEM. All you'll see under the center strip is the joint of the two halves.
Mark, yep that's what I found. Thanks.
~ Dave
