8 members (Joe H, Joe Lowe III, frogfarmer, Shade Baby, 3B, Oswald, Cosmo, 1 invisible), 66 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1224415 07/08/2017 4:09 PM
I could use some help verifying the correct front wheel bearing part numbers for my 49' 3600. I'm getting conflicting info from various sites as to the replacement part#. The inner bearing has 909526 stamped on the outer race and 909525 for the outer race of the outer bearing. These are stock bearings. I'm finding B01 for the outer. But different sites are conflicting on the inner bearing. Some sites say a B25, others say a B52. Also where have you guys purchased yours from?
Thanks for any help.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
8
8 Offline
Here are the part numbers for my '48 1.5 ton Loadmaster
Front Inner 909026
Outer 909025
Seal 379654
I have bought from Napa, Ebay, Jim Carter, and I believe Chevs of the 40's. Its been a couple years now so its not fresh on my mind. I also had to do the rear bearings and seals twice so I don't recall what I bought from where exactly. However I did write down all the part numbers because of the same issues you are describing.
Happy hunting.
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Thanks for the reply. I drove all of the races out and got the original part numbers. I'm having trouble reliably crossing them to replacement part numbers. So I ordered a set from autozone. I'm a little skeptical they will be right as they list the same bearings for a 1/2 tone and 3/4 ton which I don't believe is correct. I will soon find out and reply back.
1949 Chevy 3600
8
8 Offline
bztguy sounds like your close, once you verify all the numbers you might post them so others might have an easier time finding them.
Curt Warren
Salt Lake City
OK, I've gotten to the bottom of the correct front wheel bearings for my 49' 3600 and a better price for them. The resto places want to charge you $75 or more a bearing. NAPA wanted $131 for the inner bearing! National, Timken, SKF......they use the same part number. The inner bearing is a B46, the outer bearing is a B25. Rock Auto sells the Timken and National brand for about $50 each. Don't buy from autozone, they list the bearings for a 3/4 as the same for a 1/2 ton and a 3/4 ton has a larger spindle. I mic'd my bearings and the measurements match up to the specs that Timken has and they cross reference to the OEM numbers which match also.
1949 Chevy 3600
Rockauto.com has them NATIONAL brand.
BO1 $28
B25 $42
B46 $66
