1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#1224172 07/07/2017 2:08 AM
Good day....has any converted their 1964 k10 from drum to disc brakes? I see a lot of conversion kits available but they don't specify for a k10. I'm looking for any thoughts on doing this conversion and recommend on a kit or manufacturer to use. Thanks john
1964 K10 Fleetside Pickup Truck
DLBrooks
DLBrooks
You might consider changing your closed knuckle front axle to a later model dana 44 or a gm 10 bolt --that are already set up for disc- 73 up chevy k10 or k5. I used a gm 10 bolt from a full size 88 blazer on my 67 k10. I do not know if you will need to move the perches for a 64 --I did not on my 67.
I will guess you are running a 3.73 gear which is common on front axles with lockout hubs that have disc brakes. Or maybe you have 4.10's or other.
1959 GMC 100 Fleet
Follow in the DITY
