| | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I'm really not being lazy.... I am genuinely trying not to make a costly mistake. Perhaps I could just word it as "What would you do?"
I have a stock 6 lug drum brake setup on a 1950 3100...... what wheel size should I order to accommodate modern tire reproduction white walls?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | WHOOPS!!!!
6 lug sorry.....( I have since edited my original post)
| | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I put trailer wheels on mine. I just measured how deep they could be and not rub anything and made sure the bolt pattern matched. I don't know what the measurements are but I bet someone else will chime in with the info.
Gene 1959 Apache
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Only problem with those is that I wanna put hubcaps on and there are no clips.......
I like the price though.
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | I've seen hubcaps installed with three small machine screws- - - - -they're almost invisible if you use stainless steel. Just drill and tap three equally-spaced holes in the wheel center. Jerry
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | ^^^^^^^. 16" gives more choices in tires.
6" width is good choice. 6 lug in your case.
They are proud of their rims $$$$ | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | That's good info...... just what I needed.
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | There is a website called Hubcap Mike that has 11-5/8 baby moons for trailer wheels that are said to clear large rear hubs on 3/4 and 1 tons. I ordered mine a couple days ago and waiting for them to come.
1953 GMC 1-Ton Pickup with 350 and 700R4
