6 members (homer52, TrknGMC, Ponchogl, klhansen, Robert Crandall, Hotrod Lincoln), 37 guests, and 3 robots.
Topics128,023
Posts1,055,371
Members48,420
#1224174 07/07/2017 2:13 AM
Hi all
Well I have now found a couple of engines (4) for my 42 1 1/2 ton truck witch I will bring home for spears
The only engine I can't ID is 3835124 if someone can help that would be great
Cheers Justin
Crusing in the Passing Lane
So they must be Chevys?
Ed
Check this thread out...
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=931783
Looks like it's a Canadian 216 from 1946-47 era.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike
The link helped with ID of the engine so when I dismantle the engine I will be able to see if it's a 47 or a 48 motor
Cheers Justin
Not to hijack your thread, but I an stumped on my engine.
Stamped # on pad behind distributor is LCM7I059 (the "I" is not a 1).
The # beside the CON 4 is A 228.
The casting # on the head below the "GM" is 3835517
The date code on the head is B 191
The bosses on the sides of the engine are threaded, so it may be a car engine.
Carl
Carl,
Whats the block casting number?
Is the block SN hand or machine stamped? Look at the first 3 letter again, could the "C" be "D"?
The Head is 1950-53 with a date code of Feb 19, 1951
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Carl,
I found it...LCM is the prefix for a 1953 4000 Series 216 engine.
L = year 1953
C = 216 4000 Series
M = Tonowanda
Check your date code and see if A228 is really A223 (Jan. 22, 1953) which would line up with the serial number...
Oh, the letter "eye" is used for the number "1". Unit numbers start at 1001, so you have the 70,059 engine.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike. The A228 is probably a A223. Old eyes.
