1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1224428 07/08/2017 5:38 PM
I'm really not being lazy.... I am genuinely trying not to make a costly mistake. Perhaps I could just word it as "What would you do?"
I have a stock 6 lug drum brake setup on a 1950 3100...... what wheel size should I order to accommodate modern tire reproduction white walls?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
WHOOPS!!!!
6 lug sorry.....( I have since edited my original post)
I put trailer wheels on mine. I just measured how deep they could be and not rub anything and made sure the bolt pattern matched. I don't know what the measurements are but I bet someone else will chime in with the info.
Gene
1959 Apache
https://www.etrailer.com/Tires-and-Wheels/Dexstar/AM20758.html
Others available in alum and 15" if needed. Most if not all will not accept stock wheel covers.
Only problem with those is that I wanna put hubcaps on and there are no clips.......
I like the price though.
H Online: Content
I've seen hubcaps installed with three small machine screws- - - - -they're almost invisible if you use stainless steel. Just drill and tap three equally-spaced holes in the wheel center.
I really like these wheels that have the clips on them but I don't know which size to order.
https://www.uswheel.com/collections/hot-rod-street-rod/products/pntrdysmoothie
^^^^^^^. 16" gives more choices in tires.
6" width is good choice.
6 lug in your case.
They are proud of their rims $$$$
That's good info...... just what I needed.
There is a website called Hubcap Mike that has 11-5/8 baby moons for trailer wheels that are said to clear large rear hubs on 3/4 and 1 tons. I ordered mine a couple days ago and waiting for them to come.
1953 GMC 1-Ton Pickup with 350 and 700R4
