8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 1 Moderated | | Moderated Joined: May 2017 Posts: 1 | Just bought a set of tail lights/ break lights for a 62 Chevy PU I am working on and the new lights came with a bulb number 299. I would like to know what bulb I could as a replacement that would also have turn signals or would I need to buy a different tail light ? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They should already be able to be used as turn signals, as most tail light/brake light assemblies are already dual filament bulbs. I can't seem to find any information on an automotive application bulb with a "299" number, but most older dual element tail lamps bulbs use an 1157 bulb.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Hi Moots Back in the day the 62 would have come with 1034. The 1157 is a upgrade about 40 years ago with more candlepower. The 1157 was and is the best to use, try to find one with a brass base as that will not rust in like the tin base bulbs.
Of course today a LED unit is the one for best results. On the front the park/signal lens was clear , in 63 they went Amber. Howie , also with a 62.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The 299 bulb has the same base as an 1157. It is a suitable bulb for your truck and has two filaments. It is the European/Asian (Eurasian) spec for US 1157. So to replace: use 1157 or another TwoNinerNiner. There are several other bulb numbers that you can use but no need to go there.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Does the LED type work with 6v?
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are 6v LED bulbs available to match most old 6v bulbs, except head lights.
Which original 6v bulb would you like an LED replacement bulb? | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I guess the brake lights.
| | | | | Joined: Sep 2013 Posts: 1,363 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,363 | Don, I too need to look at LED's for my tail light as well. Lit'l bro was following me recently while I drove east late in the afternoon with the sun shining directly on the tail lights and said the 6v brake lights were not that bright.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
