9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#1224151 07/07/2017 12:27 AM
Couple quick and easy questions 😀 '47 2 ton truck. Gonna change the oil in the transmission. Book says sae 90 all purpose, but about all I see is 80w90 gear oil. Suggestions? Also any idea about what the capacity may be so I know how much to buy? Thanks.
90 or 80w90 would be OK
Fill to about 1/2" below the fill hole.
Check after 15 minutes, in case some oil is slow in getting back into the u-joint housing.
The Shop Manual says 5 3/4 pints.
Thanks for the help. Much appreciated!
