0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Couple quick and easy questions 😀 '47 2 ton truck. Gonna change the oil in the transmission. Book says sae 90 all purpose, but about all I see is 80w90 gear oil. Suggestions? Also any idea about what the capacity may be so I know how much to buy? Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 90 or 80w90 would be OK
Fill to about 1/2" below the fill hole. Check after 15 minutes, in case some oil is slow in getting back into the u-joint housing. The Shop Manual says 5 3/4 pints. | | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Thanks for the help. Much appreciated! | | |
