1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#1223993 07/05/2017 10:10 PM
Is there a correct way to mount the passenger door lock in a 1946?
Should the lock be in the open or locked position when installing the rod from the key cylinder?
Should the key/cylinder be in the lock or unlock position or in "center"?
Thoughts will be appreciated.
Harold
Harold
Harold46 #1223995 07/05/2017 10:19 PM
I believe I put mine in with both in the open position, but not sure if it matters as long as both are the same position. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Harold46 #1223996 07/05/2017 10:23 PM
Harold
I don't know if my experience with the '37 is applicable, but my recollection is the key/cylinder was in the unlock position. Note: the cylinder is in the handle in '37 models. Given the '46's are in the door, it might be otherwise?
Harold46 #1223997 07/05/2017 10:28 PM
DLBrooks
DLBrooks
I just put one in a 46 in the open position. I had to jiggle it a little ---slight turn --to get the square rod to slide thru.
1959 GMC 100 Fleet
Follow in the DITY
Harold46 #1226449 07/20/2017 11:26 PM
Tried it in open position & set the arm on the latch to open, put it together and it works!!! One more project done.
Thanks for all your comments.
Harold
Harold
