8 members (MickeyP, 37 GC, Otto Skorzeny, pauld, Ponchogl, 3B, jmoore, Rusted Nut), 100 guests, and 1 robot.
Topics128,115
Posts1,056,627
Members48,450
I have come across an SM420 transmission with the driveshaft braking system attached. I realize that these systems were used in the bigger bolts. Is the parking/e brake system able to be removed? Would I be able to use this transmission in a 1/2 ton (if the brake is able to be removed?
It's a small world, but I wouldn't want to paint it.
Yes, the parking brake parts can be removed.
Yes, but you might need a different rear cover on the transmission in order to connect to an enclosed driveshaft, depending on the year of the SM420 and year of the 1/2 ton truck.
Thanks, Tim. From what I can gather, it's a 1948-1957 SM 420.(Casting number 591953 Code above casting number is D 215) I have a torque tube rear end which I plan to transplant into my '47 with the SM 420 if I can figure out what I need for the rear side of the transmission. (I can't find any numbers on the rear end but it's 6 lug and has Bendix brakes..)
If you can get the floor section from the bigger truck it will probably fit right in your half ton. I swapped it all out in my '59 and use the brake just like it was in the bigger truck. It probably isn't the best parking brake though.
Gene
1959 Apache
Gene,
If I understand Rusty correctly he need to remove the transmission parking brake on the SM-420 so he can convert it to a torque tube type rear...you can't have both!
The transmission brake is a great brake for your pickup, if it will hold a 20,000 pound big truck it should have no problem holding a 3,500 pound pickup!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Mike B
Gene,
Mike B smile
I see what you mean. I didn't think about the closed in drive line. I was just thinking about the extra hole in the floor for the parking brake. I should have just kept quiet as I know nothing about torque tube set-ups. Never mind.
Gene
1959 Apache
