8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny),
125
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | I bought one of the PreVal paint sprayers from Jim Carter awhile back and I just want everyone to know how great I think it is. I hesitated to use it for quite awhile but then about a month ago decided it was time to paint my engine. I'm completely impressed with the job this thing does. I bought a quart of the olive green high temp paint from Carter as well. It required a thinner but once I got past the mess of pouring paint into the small container & mixing it that little spray system is just awesome. The air refills are available at most automotive paint shops and are really inexpensive. For the money, I think this is one of the best things you can buy. Just my 2 cents.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Check your local Home Depot or Lowes for the refills also. If you plan on using it a lot you may want to Google Preval and order directly from them by the case. 12 or so in a box.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Great point, Bruce. Our local Home Depot carried the refills up until a month or so ago, then they discontinued them. Lowe's doesn't have them here, either. But I'm sure HD & Lowe's probably have them in other parts of the country. Either way, those refills are only about $4 apiece.
