| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I have a 1949 3100 truck. I was wondering, would the shock towers off a 1954 truck work. By that I mean would it be a bolt on swap? Are the holes already drilled in the 49' frame? I see some holes in the frame but not sure if they're the right ones. Don't want to cut them off if they want work. Some day someone might need a 54 frame. Thank for the input.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | You will need to make some new holes in the frame.
