Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Stovebolt48, cmayna), 180 guests, and 5 robots.
Topics128,283
Posts1,058,504
Members48,490
I'm currently restoring a 51 GMC 9300, when going through all the front end and brakes found I had a spun outer bearing on one of my hubs. Having a hard time finding a replacement. Restoring to all original, so need to know where I can get a new 6 bolt hub for this thing. Any help appreciated. Can only seem to find 5 bolt conversion hubs.
All Canadian
51 GMC 9300 1/2 ton
55.2 Chevy 1600 2 ton
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
My truck came from Crystal city Manitoba . There was a lot of old trucks around might find a parts truck in the rural areas
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Thanks for quick replies. I will give rpm classics a try.
All Canadian
51 GMC 9300 1/2 ton
Anyone know what year ranges and models of vehicles that use the same hub? Would make my search a little easier.
All Canadian
51 GMC 9300 1/2 ton
If you look in the GM parts catalog for your year and preceding years, you will be able to see when the hub was used. The parts catalogs are online at "Old Online Chevy Manuals". Your Canadian truck is the same as a Chevrolet as far as the mechanical aspects are. Bill's truck here in Ontario would most likely have a hub for you. The RPM guys are really good too but it would be shipping across the border.
1951 1 Ton Completed
