2 members (Gdads51, moparguy),
96
Mod | | | Forums66 Topics128,180 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 5 New Guy | | New Guy Joined: Apr 2016 Posts: 5 | I'm currently restoring a 51 GMC 9300, when going through all the front end and brakes found I had a spun outer bearing on one of my hubs. Having a hard time finding a replacement. Restoring to all original, so need to know where I can get a new 6 bolt hub for this thing. Any help appreciated. Can only seem to find 5 bolt conversion hubs.
All Canadian 51 GMC 9300 1/2 ton 55.2 Chevy 1600 2 ton
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | | | | | | Joined: Sep 2010 Posts: 2,331 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,331 | My truck came from Crystal city Manitoba . There was a lot of old trucks around might find a parts truck in the rural areas | | | | | Joined: Apr 2016 Posts: 5 New Guy | | New Guy Joined: Apr 2016 Posts: 5 | Thanks for quick replies. I will give rpm classics a try.
| | | | | Joined: Apr 2016 Posts: 5 New Guy | | New Guy Joined: Apr 2016 Posts: 5 | Anyone know what year ranges and models of vehicles that use the same hub? Would make my search a little easier.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you look in the GM parts catalog for your year and preceding years, you will be able to see when the hub was used. The parts catalogs are online at "Old Online Chevy Manuals". Your Canadian truck is the same as a Chevrolet as far as the mechanical aspects are. Bill's truck here in Ontario would most likely have a hub for you. The RPM guys are really good too but it would be shipping across the border. | | |
