1 members (baldeagle), 68 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#1223841 07/04/2017 4:08 PM
While attempting to loosen the hood lock bolt as described in the Shop Manual page 11-3, I am not able to get the bolt to turn even after using penetrating oil and a heavy duty screw driver. It probably has not been adjusted in decades. Any suggestions?
Did you loosen the nut on top? It's behind the panel that the catch bolt is attached to.
Does your top plate look like this? I believe it just has the captive nut on it? If it does let the PBlaster work as it will twist off.
https://www.flickr.com/photos/advance-design_parts_co/14918262974/in/album-72157631868452754/
