4 members (Gray_Ghost, Jon G, Otto Skorzeny, 1 invisible), 96 guests, and 8 robots.
Topics128,181
Posts1,057,189
Members48,465
does anyone have a matching set? i need both driven and drive gear as mine are stripped
bgtw my truck is a 4 speed but was wondering does a 3 speed set fit physically? i know the reading will be off
Crusing in the Passing Lane
Speedo shop should have gears, however, might be best to search shops in US.
Ed
3 speed gears will not fit a 4 speed.
My Blog
thanks guys,
3 speed speedometer gear set looks like it will physically fit.....is the shaft a different size?
The gear that screws into the transmission housing looks to be the same for 4sp/3sp, but the grooves will most likely be different for 3p vs 4sp?
Also, I dimly recall that the gears on 3sp/4sp internal shafts/couplings are different internal diameters?
Maybe someone will confirm/correct and post links to some photos?
