| | | Forums66 Topics128,180 Posts1,057,154 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | I did a 46 bed about a year ago, and swore I was not going to do bed bolts again, on my back. Unfortunately, I have a guy, (that was unable to do his truck) that I volunteered to do his bed.
Since it is just me, how can I mount the flat washer, lock washer, and bolt, fighting gravity. Surely someone has a secret. I need to know the secret.
Thanks.
Steve
'46 Chevrolet 1/2 T. Pickup, survivor - sold '31 Ford Model A pickup
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Put something heavy over the bolt first. You don't need too much to keep it from pushing up while you are putting the washer/nut on by hand. I used a plastic container I have that is full of bolts.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | mtntrk: I concur w Dennis about putting something on top of the bolt to hold it down from the top, but you're right about putting those fasteners on from the bottom. I did the bed on my 48 a few years ago and was also frustrated until I had a lightbulb moment: drop the nut into your socket and then position your lock washer and flat washer on the edge of the socket; then use masking tape wrapped simultaneously onto the outer diameter of the flat washer and the socket to hold it all together while you get the nut started onto the carriage bolt. Worked like a charm. Good luck....Dave | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Thanks for the suggestions. I can control the bolt with a weight. It's the washers and nut that get me.
I've been thinking about some ways to McGyver this. I'm going to try a couple tomorrow to see what works best. But I'm still open to ideas.
Steve
| | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Duct tape would also work. Or how about a telescoping magnet put thru the nut and washer to hold the bolt in place?
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Don, good idea w the telescoping magnet, but didn't help in my case, as the carriage bolts I used on my bed were non magnetic stainless steel....that's why masking tape (or duct tape) to secure the washers to the socket worked so well. | | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Darn stainless bolts! I didn't think about that. But they do last. Always lube stainless bolts, as they will seize up sometimes.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2015 Posts: 11,159 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,159 | Is there a rule that says you have to assemble the bed in it's final position? How about standing it on the front end? That would definitely simplify installing all the bolts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | How about little blobs of plumbers putty to smush the loose parts together so they can be assembled as a unit?
| | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | Super glue the three together . Using a piece of wood with a hole in it push the bolt from bottom set flat washer lock washer then thread the nut on a couple of threads , drop glue on the bottom edge of nut and outside edge of lock washer . Let dry turn bolt out repeat. Hot glue works best if you have one available. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I do not have stainless so I put a big magnet on the bolt head. Keeps everything together. I did use masking tape at one point to corral the washers and nut and I still find remnants of the tape stuck to the nuts years later. | | | | | Joined: Sep 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2017 Posts: 36 | painters tape over the bolt works great, also helps with fender bolts. It doesn't leave a residue like duck tape can do. Can tape them all at once then don't need to keep going back and forth once under the truck . I use 1 1/2 inch painters tape and just a little piece over each bolt. When done just pull it all off and done | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Little bit of grease sticks them all together long enuf to tighten. Quick wipe down and on to the next | | |
