8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just finished converting my truck to a 12 volt system with a generator. I did it mainly for the headlight improvement. For the headlights I used a reflector type setup with an H4 bulb. When they are off they look very similar to the original sealed beams. They perform almost like a modern car headlight. The high beams are really exceptional. I bought them from Octane Lighting and they fit right into the pot without a problem. You can get the same performance with a six volt bulb that they sell. However, at 65 watts, you would want a relay to supply the lights. | | |
