2 members (cmayna, Wickedbass),
71
Mod | | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 78 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 78 | I was experiencing intermittent horn sounding upon press the steering wheel horn button. I checked the connections at the relay. One connection appeared to be poor. Also the horn contact insert seemed worn down. The problem now is the horn sounds if I connect the disconnected wire to the middle terminal. Is that the correct placement? I am pretty sure that is where it was? Otherwise the horn button must be grounded without pressing the button. Please check the photo .. i wanted to attach a photo..forum doesn't allow a simple method from my phone gallery.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Amen on the pic posting thing. The reasons that don't allow it are explained on the main page and are valid. Your relay is a single pole-single throw type switch or relay. Grounding one side of the relay, via the horn button, moves a relay contactor to make connection between the 6 or 12 volt connection and the horn connection. Remove the horn wire and alligator clip in a bulb or voltmeter (to save your ears). Move the wires around until you get it right. You will not hurt anything.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you cannot get a good beep/honk, run a ground wire from a cleaned-to-bare-metal horn mounting-point/bracket to a engine-ground-strap bolt (just to see if a bad/weak ground from the horn body is your problem). | | |
