2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | I've got a 55.1 3600 and would like to add hitches. I found the info for the receiver hitch at TBRT. (Thanks, Bolters!) But, I haven't found a source for a gooseneck hitch.
Does anyone have any knowledge/resources on gooseneck hitches to fit a 54-55.1 Chevy 3600?
Thanks.
I love this bar. It's my kinda place.
Jeffry
[Edit: I'm in North Texas, if you have local info.]
1955 Chevy (1st Series) 3600
| | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | You can get get gooseneck ball kits specific to year and model of truck.esp the newer trucks. Not so for the old iron. But you can get just the ball mount ( no mounting hardwarr)and fab your own mounting brackets to custom fit your truck frame. There are various styles of ball mounts so you would need to pick to your liking. Have fun! Best source would be a shop that specializes in truck assecories. And me being in Canada...cant give you Texas local info ..!!
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have a half inch thick piece of steel with a ball mounted in center, used angle iron bolted to web on each side of frame.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have the center plate for a B&W turn over ball hitch and will fabricate my own crossmembers/brackets for my 6400.
A 3600 might not have enough springs back there to take much hitch weight from a gooseneck, certainly not like the present day pickups do.
Please elaborate on the tag along hitch you found for the 3600.
Years ago I found one perfect for my 3800 (and then moved it to the 6400) but never knew the intended application to get another. The frames on these AD trucks 3/4 ton through 2 ton are 36" wide outside. Most modern stuff is 34", so most hitches don't fit easily. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For years there were no "kits", you just fabricated your own mounts so that is still an option today. Don't know what you are going to be hauling/towing but if it requires a goose neck the FIRST thing that needs done is brakes on the truck and a must on the trailer. In my younger (foolish) days I towed a race car all over the U.S. with a 53 3600 and a V8 engine. Would PULL anything and STOP nothing. Seat cover was covered with butt bite marks but shear luck got me through with no bent tin.
Evan
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | Thanks for the responses. Grigg, TBRT Engineering has the receiver hitches. http://www.tbrtengineering.comCoilover, what was the total weight you towed? And, were trailer brakes insufficient to make up the difference in stopping power? For y'all that have fab'ed your own mounts, can y'all post/send a pic? I've not fab'ed anything structural. So, I would have to design it for someone else to weld it up, or rely on bolts with welds to safety them. Thanks again.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I do not know about gooseneck hitches, but I do know about the 54/55st TBRT Engineering hitch (it might be out of stock - discontinued). It fit perfectly in my 1954 3104 pickup. It is strong and well-made. But, I'll have to hang my rear license plate elsewhere? http://www.tbrtengineering.com/classic-towing-products.htmlIt looks like they will sell out what they have in stock, and make no more. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Race car (Sprint) was 1790#'s--heavy by today's standard, trailer around 1000#'s, extra tires,wheels, fuel, parts, probably another 1000#'s. Total about 4000#'s which is not that much unless you're trying to stop it quickly.
Evan
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | Did your trailer have brakes? I ask because I had a 30' RV that I pulled to CA & back with a 1/2t Suburban. It weighed 4700#. The brakes on the trailer alone would stop the truck & trailer.
Wouldn't trailer brakes stop the 3600? I've found a '56 3800 with a 327. Needs a carb, which I have. But, I would rather not buy a 1t, unless I have to.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | In the US a trailer rated 3,000 lb or more requires brakes, and also a yearly inspection/sticker. | | | | | Joined: Aug 2001 Posts: 3,617 Moderator | | Moderator Joined: Aug 2001 Posts: 3,617 | Grigg Shouldn't that be 30,000 lb?
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Any trailer over 3,000 pounds like Grigg says, just makes good sense, towing vehicle is also a consideration, of course, if one is pulling a 5,000 trailer with a 2 axle tractor, not really necessary. Just good sense.
Ed
