2 members (Tony292, baldeagle),
32
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 12 New Guy | | New Guy Joined: Jan 2015 Posts: 12 | afternoon folks, I have just returned from picking up a parts truck ( 1950 One ton longbox ) and after going thru the truck my dad wanted to see if it would run, been parked for 5 years, after filing the points and changing the fuel pump it started, I put a rad and hoses on it this morn and started it and i noticed that the crank pulley was loose. after looking at it you could see the bolts had loosened on the backside of the harmonic balancer, I used a puller and pulled it off, no driftkey, bunch of blobs of welds, a nice mess.my question is can I grind out the weld that filled the key in the crank ? Can I tap the end of the crank , dont want to pull the crank and the motor seems to run well ? any ideas ?? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Yes you can tap the end of the crank. Get in touch with Hotrod Lincoln.ðŸ›
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Unless the balancer is keyed to the crankshaft in some way, the tension of the fan belt and the load of driving the charging system and the water pump will eventually unscrew a center bolt. Jerry
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I'd say if you were careful, you can remove the weld material.........just don't take more than the weld material.
1959 3100 Apache Fleetside
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | How dos the inside of the damper look where it slides onto the crank- is it galled at all?
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | It would require a lot of time and effort, but I'd suggest removing the timing cover and reshaping the Woodruff key slot with a cutoff wheel on a Dremel tool. Then a custom-fitted key could be filed for a tight fit to both the crankshaft and the balancer.
To do it right would involve removing the crankshaft, welding up the key slot, and cutting a new one with a Bridgeport mill. A replacement crank would probably cost less. Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | On an internally balanced engine it is OK to make a new key way 180 degrees from the factory one in both the dampner and crank snout. Can't do this on an externally balanced engine like a 400sbc or a 454. The fit should be close, 0.0005 to 0.001 so the balancer can't "waller" during acceleration/deceleration. We have an ancient key way machine that can actually do this with the engine assembled but by the time the front clip is pulled and the machine set up a Bridgeport would probably save money. Machine is now used by a friend to put new key way for drive pulleys/sprockets on ditching machines. When one of these machines is down price is not discussed to get it back in action. X2 on replacement.
Evan
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Since no timing marks are involved on a stovebolt balancer, the placement of the keyway isn't critical. If the keyway in the balancer is damaged, either have a new one broached in a different position, or just replace the balancer with a good one. Getting the keyway in the crankshaft straightened up and making a key fit tight is the critical operation. Jerry
