2 members (baldeagle, dunfire), 50 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1223344 06/30/2017 11:33 PM
Looking at a '62 Chevy SNB 1/2 ton. I know all the rust spot concerns. Is there anything specific to the 1962 model I need to watch out for?🛠
Justhorsenround #1223402 07/01/2017 12:42 PM
Suspension differences but nothing to worry about. 1 yr for grill hard to come by clean ones. What is snb? Got me on that acronym.
~ HB
1962 Chevrolet C10
1962 Suburban
Justhorsenround #1223405 07/01/2017 1:42 PM
Short narrow bed. Thought everyone knew that one. May be a moot point as the guy is not a motivated seller. Too busy to respond to my emails and did not provide a phone number.🛠
Justhorsenround #1223439 07/01/2017 7:12 PM
frame dimensions are different also and x frame in 2 whl dr.. last year year for 235 I6 and also hydr clutch
ron
Justhorsenround #1223446 07/01/2017 8:26 PM
Thanks. Finally spoke with the owner. He insists the engine is a 230. Going to look later today so hopefully I can figure out the difference.
Justhorsenround #1223477 07/01/2017 11:38 PM
The truck was almost as advertised. The engine is a 235 and runs as it should. Even has the original air cleaner and someone already plumbed it for a PCV valve. Someone installed a quality floor shift many years ago. A little Bondo in the usual places. Doors open and close nicely. No rot found, floorboards and rocker panels are excellent. Has the factory side mount spare carrier. Bench seat is out of ? and not bolted down. Grill is good, bumpers good and tires are deep in rubber. So............................I pulled the trigger. Got it for what I considered to be a very very good deal. Pick it up Monday. It's been 45 years since I owned a mid 60s Chevy truck. It's going to look good sitting next to the '48 Burb.👍🏻
Justhorsenround #1224057 07/06/2017 12:24 PM
Howdy Martin
Congrats. on the purchase of a 1962 short step side. Hope that you have lots of fun with it.
As said by others the 62 was the last year of the Torsion bar suspension. They have a wider frame and therefore different cab mount locations.
The grill went to single 7in headlamps, the interior paint color is lighter than 60/61.
The Stovebolt 235 / 261 engines were used for the last year. (early 63 4x4 did still get them) Light trucks had hydraulic clutch actuation. (heavy trucks kept it for a few more years.)
The side trim and any two tone paint was new in 62 and was used up to the end of style in 66. (Chevys only not GMC)
Enjoy your truck and post photos if you can for us to admire.
Howie also with a 62
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Justhorsenround #1224061 07/06/2017 1:29 PM
Thanks Howie, Noticed the clutch when I had it on the lift Monday. Torsion Bar suspension is a new one for me but it seems to work properly. Decoded the casting numbers yesterday and the engine seems original to the truck. Seems to run good. As for photos, I just can't get the hang of Photobucket and my Computer Engineer son just doesn't have the time to do it for me or teach this old dog new tricks. drive
