1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I'm getting ready to order the brake lines for my 1950 suburban 1/2 ton. They have two versions available for that year. One with 3/16" Rear axle lines and one with 1/4" Rear axle lines. How do I tell which ones are correct for my old Burb?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | start with determining the size of your brake cylinder fittings, including the master
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Forgive me but I am very green at this stuff......
I do not have a Master Cylinder or brake cylinders yet (ordering at the same time from classic chevy parts).
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | When its talking about 3/16th" or 1/4" is that referring to the screw in part. Could I just measure where the hose connects and get the information I need?
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Hmmm......
Maybe I should build the brakes, hubs, etc. BEFORE I worry about the lines.
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | 3/16 is usually for Disc brake and 1/4 usually for drum. The 3/16 line should use a 3/8-24 threaded tube nut and the 1/4" a 7/16-20 threaded tube nut | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Thank you....that's what I needed to know.
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | 1/4" it is! I'm going drum.
