Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (frogfarmer, UtahYork, TexasFarmTruck, Pre '68 Dave, Shade Baby, Dakota Bob), 176 guests, and 5 robots.
Topics128,277
Posts1,058,442
Members48,490
#1223423 07/01/2017 4:53 PM
I'm getting ready to order the brake lines for my 1950 suburban 1/2 ton. They have two versions available for that year. One with 3/16" Rear axle lines and one with 1/4" Rear axle lines. How do I tell which ones are correct for my old Burb?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
start with determining the size of your brake cylinder fittings, including the master
Forgive me but I am very green at this stuff......
I do not have a Master Cylinder or brake cylinders yet (ordering at the same time from classic chevy parts).
When its talking about 3/16th" or 1/4" is that referring to the screw in part. Could I just measure where the hose connects and get the information I need?
That is the line diameter.
Lines/tubing diameters and the matching wheel cylinders might have been changed/replaced over the years.
There is some line/tubing diameter info in the Shop Manual.
Hmmm......
Maybe I should build the brakes, hubs, etc. BEFORE I worry about the lines.
3/16 is usually for Disc brake and 1/4 usually for drum. The 3/16 line should use a 3/8-24 threaded tube nut and the 1/4" a 7/16-20 threaded tube nut
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
Thank you....that's what I needed to know.
1/4" it is! I'm going drum.
