1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#122331 10/03/2006 9:50 PM
i sanded down my frame by hand and cleaned it well. Looks like a have a minor patch of surface rust here and there. I was planning on coating it with "zero rust" followed by a self etching primer. Is this a good idea, or should I just use the self etch primer over the frame and skip the rest preventer step?
Thanks-Dan grin
my truck gets better every day...every PAYDAY smile
#122332 10/03/2006 10:08 PM
Self-etching primer on top of zero rust does not sound right. There would be no metal to etch.
Maybe a pro will comment on this.
#122333 10/03/2006 11:56 PM
Thanks tclederman. At first I thought the same thing, but then the rust preventer only changes the rust (using phosphoric acid)and leaves the metal treated. I'm just not sure if this will be suitable to have underneath the self etch primer... I'm thinking that the primer will "eat" into the rust converter and grab into the metal, but the wing nut at the paint store was "like unsure about that dude"...
Dano
