0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | My 1/2 ton truck 1953 with a 12 volt system has aftermarket directionals with a 4 way flasher. When I used the flasher today it blew the 5 amp fuse..... Is that enough fuse for a setup like this ? ...I replaced the fuse and directionals worked but when I used the flasher it blew the fuse again....is it a problem with two low a fuse or a short inside the unit or something else ?
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Start with a 10 amp fuse. If you're trying to flash 4 bulbs at once, that's definitely going to be more than 5 amps. If you're simply selecting a right or left turn, you might draw less than 5 amps, but it's going to be pretty close to maxed out even then. Most fuses need a 20% surge capacity over the anticipated constant load. Jerry
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Thank you jerry....I will post when I find what cures the problem....
