| | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 22 New Guy | | New Guy Joined: Mar 2010 Posts: 22 | So I believe my original turn signal switch has died in my '64 C20...I lost all my turn signals yesterday. I know all my grounds are good as I replaced and added additional grounds when I rewired the entire truck about 6 years ago. I've had the steering wheel off many times in the past trying to correct the turn-signal cam not cancelling after a turn. I finally gave up thinking the replacement parts were just not up to snuff. Now I'd like to replace everything turn signal related with the best parts available. Can anyone recommend/had a good experience with a particular brand or re-seller?
I see parts listed on Classic and American that say "Reproduction" but then they have a version that says "OE quality"...are the OE actually better...they seem to be $20-30 more.
Thanks!
1964 Chevy C20
| | | | | Joined: Mar 2014 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 92 | This may be a stupid question, but you didn't mention a possible fuse burned out. Sometimes it can be an easy fix that you overlook. JP | | | | | Joined: Mar 2010 Posts: 22 New Guy | | New Guy Joined: Mar 2010 Posts: 22 | Hey JP,
Yes, thank you, I already corrected the problem...bad blinker relay (2 year old China part). I put back in the relay that I know is at least 30 years old and everything started working again.
I spoke to Classic yesterday who indicated Reproduction means the wire colors are not correct...where the OE turn-signal switches have the correct wire colors. Not sure I want to tear back into the column just to fix the cancelling problem. Maybe a winter time project.
Greg
1964 Chevy C20
