6 members (Nick in Manitou, Chip O, Otto Skorzeny, MickeyP, Jay R, 1 invisible), 118 guests, and 5 robots.
Topics128,026
Posts1,055,405
Members48,422
#1222775 06/26/2017 3:57 PM
I was wondering what the coil supply voltage should be,key in the run position engine off. My engine quit on me yesterday , this is a 1962 261 in a gmc, I wasn't getting any spark, and I measured 5.8 v at the coil key on not running, I installed a wire direct from battery to coil and it fired right up. After getting home I pulled the by-pass and it restarted on the normal truck wiring.again I measured the voltage at the coil and it was around 5 v engine off, but it was 9.6 v engine running . What's going on? This engine is 1 year on rebuild all new ignition parts at rebuild.
1962 GMC 920 step side 261 4 spd
GMC,
I just found out the hard way that I need a resistor on the positive coming into the coil. (OPS!) My truck also stopped while I was driving it down the road due to a extremely hot coil. Once it cooled down, she started right back up and I was able to limp her home. I am dealing with all the gremlins involved with mine.
I am thinking out loud after learning from my MANY learning opportunities over the past month.
Did your coil get hot or just warm? (I assume warm due to the Voltage change, but not hot)
How long did you wait before you ran the wire directly?
Do you have a bad battery (if you ran wires directly then you may have bypassed other things that would create a draw)
Do you have a bad ground or bad/loose wiring? Have you changed/alter anything recently that might caused this issue?
Good luck and keep us all posted. I am sure that many others may have this same issue and will read this.
Chris
9-10 volts with the engine running at the coil (+) terminal is about right. Don't be surprised if the next time you measure voltage "key on engine off" if you get full battery voltage. That happens if the engine stops with the points open. Resistors only reduce voltage if they're flowing current at the time the measurement is made. You need to rig a bypass wire to the coil input while the starter is turning. If you're using a stomp starter, install the stomp switch intended for 55-62 engines with the small bypass terminal on the side.
Jerry, is that the stomp switch you were referring me to over the phone last night?
GMC kid 7530 #1222818 06/26/2017 10:41 PM
On a 6 volt system without a ballast resister, what are we trying to "bypass" with the '55-'62 bypass starter switch?
Based on my interpretation of the OP's descriptions, I would suspect that he has an issue with his ignition switch or associated wires, preventing full battery voltage (or very close to it) to the coil.
Carl
GMC kid 7530 #1222823 06/26/2017 11:16 PM
If he's getting 9.6 volts at the coil on a 6V system with the engine running, he's got some serious charging system problems as well as ignition trouble. I'm betting a 62 GMC has a 12 volt electrical system.
ndkid275 #1222824 06/26/2017 11:19 PM
Yep, same one. Try one of the online parts places like Rock Auto and search for a starter switch (not ignition) for a 1960 Chevy pickup with a 235 engine.
AC Delco D928A Copy/Paste this link for a photo:
http://www.rockauto.com/info/301/D982A_Primary__ra_p.jpg
Missed that crucial tidbit. I got the 2 "kids" mixed up (one of them has a '51 truck).
GMC kid 7530 #1222949 06/27/2017 10:53 PM
sorry for confusing you dad!
