| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | I tried using rubbing alcohol on a few parts one day to remove some of the oversprayed paint from some of the parts, and it seemed to do very well.
It's a bunch cheaper than Lacquer Thinner, so I figured why not use it.
I got quite a bit of overspray on the clear back-up light bezels, so I decided to take a Tupperware type dish and put the bezels in that, submerged in the alcohol and let them sit for several days.
Man, that was a BAD mistake. It looks like the alcohol was steady eating away at the plastic, and the lens is no longer clear at all. It has a white smoky appearance to it now.
Guess I'll hafta make-do temporarily until I can buy new ones.
I ended up "brush-painting" the inside housing of the taillights and backup lights with a Chrome paint. Had I known in advance that I'd be doing that, I'd have removed the bezels before spraying.
I know I could have also masked them off, guess I was just in a hurry. I'll know better next time.
~ davey 1967 Chevrolet 1/2-Ton PickupIn the Stovebolt GalleryI'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.I've forgotten more than I ever knew. Okay, where did I put it? A man can never have enough tools
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You might be able to polish them back to clear with a plastic polishing kit.
