Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Sjm), 152 guests, and 5 robots.
Topics128,278
Posts1,058,457
Members48,490
#122275 09/30/2006 12:40 AM
Anyone ever used Nason 421-40 Spray filler? I'm trying to find an answer for a friend that is having trouble spraying the product. Trying to find out if it can be reduced and if so what to use? Looked at Dupont's site about the product and they don't tell anything about reducing. Any info would be appreciated. Thanks!
#122276 09/30/2006 3:30 AM
...spray filler....
golly I have no idea if this is the stuff we used in the shop a few months ago. But we painted a carbon fibre race car and had to give it a coat of this real real real thick primer (and I mean real thick). The trick was you need a 3.0 tip on your gun (huge I know).
...but then again, this might not be the stuff your talking about at all....
Good Luck
#122277 10/02/2006 1:49 AM
I use a cheap gun with a 03 tip .IT can be thinned up to 10% only a guess!, with acetone or urethane reducer. I have done this the only thing is it really slows down the drying.I let mine dry a few days and then lightly block with 180 dry to open and let solvets escape then set in sun for a day before i finish blocking
Popa Kents Body Shop
#122278 10/02/2006 6:19 AM
Yeah, it's polyester primer and it really does need at least a 2.0 with a 2.2 preferably.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#122279 10/02/2006 3:47 PM
Tab Offline
Years ago I bought some "heavy building primer" which was designed to go on thick to fill minor imperfections. I like the idea of a this new stuff though and I'd like to have some on hand.
Where can I get a 3.0 tip for my Chinese gun?
delete my account and pictures
