1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1222544 06/24/2017 5:55 PM
Dear Stovebolt, I have a GM Rochester carburetor on my 1950 235 engine and it runs way too rich. The manual gives a measurement to adjust float drop but only shows a paper or sheet metal gauge to adjust the float level itself. Would anyone know where I could get one of those. or trace one or find a dimension to be able to adjust the float?
Also I haven't been able to find a paper air filter to replace the original mesh in the stock air filter. It measures 8" O.D., 6 1/2" I.D. and 1 1/2" high. Any ideas?
Thanks a lot for all the forthcoming help and advice offered in the past. Yours, DaveB4
Riding in the Passing Lane
The float level measurement is 1 9/32 in. With the air horn upside down & the gasket in place measure from the gasket surface to the bottom of the float.
There is a hole in the bottom of the carb base . Make sure there is a passage in the gasket to allow that hole acsess to the interior of the intake manifold.
If that is blocked the carb will run rich.
1972 Chevy c10 Cheyenne Super
U
U Offline
As Mr. Wrenchbender says, you need a 1-9/32" device to measure this float level with. Plastic is good. I think I made one from a piece of plastic poster board.
Wrench Fetcher, PhD
I use something similar to this:
https://www.amazon.com/gp/aw/d/B000...Pl=1&dpID=41qhjME4xML&ref=plSrch
Measure with the gasket in place.
1951 3100
