7 members (Otto Skorzeny, Hotrod Lincoln, Slick Willy, 1955 1 Series, GrandpasJimmy, BarryP, 1 invisible),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,925 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | A couple of years ago I was having an overheating problem with the 216 of my 1952 1/2 ton. The mechanic said there was exhaust gas in the coolant. I removed the head and sent it to a machine shop. They didn't find any cracks and milled a few thousandths off. I took the radiator to a shop and had it cleaned out. They fixed a couple small leaks. After I reinstalled the head ( with a new head gasket) I back flushed the block. That seemed to fix the problem until a few weeks ago. It doesn't overheat at highway speeds, but when it's idling the temperature gauge starts to move up. I had the test redone that indicates there is exhaust gas in the coolant again. My question is: is there any point in trying to tighten up the head bolts without replacing the head gasket?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Feb 2004 Posts: 29,854 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,854 | Back up the head bolts about 1/2 turn, and retorque them, one at a time after warming the engine up to operating temperature. It can't hurt, and it just might fix a seep compression leak. Did you use any type of thread lubricant or anti-seize compound when the head was installed? Dry threads tend to under-torque fasteners from thread friction. Jerry
| | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Hot rod, No, I didn't put anything on the threads. I will try your suggestion. Thanks for giving me some hope. Don
| | | | | Joined: Feb 2004 Posts: 29,854 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,854 | Next time, try a dab of Never-Seez on the bolt threads, and just a little under the head. It prevents torque loss from thread friction and gives a better, more uniform stretch to the bolt. Jerry
| | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I retorqued the head bolts yesterday. So far so good, but the weather only got up to around 70 today. While I was working on it, I discovered one of the spark plugs was loose enough to turn with my fingers- probably unrelated to my overheating problem? Can I wait for a few days and have the coolant rechecked for exhaust gases again?
| | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Does anyone know how long I should wait before I have the coolant retested for exhaust gases?
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | If you feel the need you can do it right away. That is as long as you have run it long enough to get up to full operating temperature.ðŸ›
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Back up the head bolts about 1/2 turn, and retorque them, one at a time after warming the engine up to operating temperature... What would be wrong with removing each bolt completely in order to apply antiseize? What about loosening all the bolts at the same time in case the bolts weren't tightened in sequence?
| | | | | Joined: Feb 2004 Posts: 29,854 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,854 | I'm pretty reluctant to loosen all the head bolts at once- - - -too much chance of the head shifting in relation to the block and the gasket and maybe creating areas that won't re-seal. I'd recommend draining the coolant far enough that any open-bottom bolt holes won't create a gusher if the bolts are removed one at a time to apply anti-seize. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | ARP actually has their own thread lubricant, and I can pretty much guarantee that there are no performance engine assemblers that use dry bolts.Even the specs in the manual are for lubricated bolts, using engine oil, but not dry. I have worked industrial maintenance for 40 years, I very rarely install a bolt dry in anything. I would definitely use never seez, if you are really that concerned, the bostick brands actually have a chart of how much to reduce the torque to compensate for this sort of thing. | | | | | Joined: Feb 2004 Posts: 29,854 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,854 | I reduce the torque spec by 5% when using never seez, and I haven't broken a head bolt or any other lubed fastener in the 40-something years I've been doing it, including building a few hundred race-winning circle track engines. Those folks who disapprove of my methods are cordially invited to observe the sprig of mistletoe attached to my coat tails and act accordingly. Jerry
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Link to ARP .........an excellent tech paper on the topic. They mention the type of surface coating, lube the bolt head surface and reducing dry torque by 20-30% when lube is used. They stress the need for a repeatable method is needed. http://arp-bolts.com/p/technical.phpI agree lube can be a good.....but.......using the dry torque spec and lubed threads, on used bolts, might cause a novice mechanic some head ache.........this warning or caution Might not apply to the experts in the crowd. ( with or without a sprig)
| | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | My engine is still overheating. Not bad but if it sits at idle for a few minutes the temperature gauge starts creeping up ( it didn't used to do that). I was talking to another stovebolt owner about it and he asked me if I had retorqued the head bolts soon after I put the head back on. I had not. In his experience the bolts loosen up within a few hours of running, and this could be the cause of the exhaust gases still getting into the coolant. Does anyone agree with him? He suggested I take the head off again and put a new head gasket on, but this time retorque it after a few hours of driving it. Is that worth a try?
