3 members (Gray_Ghost, Peggy M, 1 invisible),
117
Mod | | | Forums66 Topics128,185 Posts1,057,274 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I need to seal up the heater hose ports in my thermostat and water pump as I am not using them. What techniques have you used to accomplish this?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Take a piece of heater hose and loop one to the other.ðŸ›
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Holy cow.... that is smart.
On a side note.... What do you guys use for thread sealer so water doesn't leak around the threads of the fittings?
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Plumbers dope or teflon tape.ðŸ›
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Make sure you use the copper-colored stuff, it has copper in it. It stays semi-solid and keeps the threads lubed in case you want to undo the nuts or bolts. Most of the other stuff hardens like concrete, and sometimes chips away; and can be darn near impossible to loosen. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Your heater hose fittings should be threaded into the housing, pipe threads. Pipe plugs, brass or iron should fit.
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Your heater hose fittings should be threaded into the housing, pipe threads. Pipe plugs, brass or iron should fit.
Ed Agreed, this type of plug.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Thanks for the link to the Dorman plug. That's exactly what I need.
