8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln), 107 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#1222264 06/22/2017 12:35 PM
I have a 1942 Chevrolet 1-1/2 ton truck that the head and dash lights just stop working as the truck was standing still idling. Hope someone can come up with a quick fix. Thanks!!! 1-262-392-2989 or [email protected]
Marv.
V
VEW Offline
V Offline
Sounds like it could be a ground wire.
~ Victor
1957 3100 - moved on
Dimmer Switch! Pull the connection, clean it and reinstall. Five minute job. drive
Seeing that both dash and head lights are out, another possibility would be a bad connection at or in the head light switch.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
Check for dirty points at the thermal fuse on the back of the headlight switch.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
If you look at the wiring diagram, you will see that the headlight switch has a fuse. If that fuse blows it will cause the symptoms that you have described.
1951 1 Ton Completed
Found the headlight fuse bad for starters what size fuse do I need to replace it. Can't read what was on the old fuse. Thanks!!!
Marv.
Was looking on the sides of the fuse I found the number on one of the ends 30amp will try a new one and let you know if that does the trick. thanks again !!!
Marv.
The problem was the fuse but there is a short in the headlight harness will need to replace those wires. Thanks to all for your help!!!!
Marv.
Who makes just the headlight harness for a 1942 1-1/2 ton truck need both sides?????? Thanks!!!
Marv.
H Online: Content
Before you go to the trouble to replace the harness, disconnect the dimmer switch and test it for shorts. It's not uncommon to get a short to ground inside the dimmer.
V
VEW Offline
V Offline
Good point Jerry....as usual!
~ Victor
I am sure it is the headlight harnesses wires going though the fenders to the headlights they were touching the fender and bare. The insulation is starting to fall off after 75 years, replacing the complete wiring is not a job I am wanting to do. For now I am only going to replace what is causing the problem and I have checked out the cost of a complete harness from Jim Carter $600.00 WOW!!!! Thanks again for all your help.
Marv.
Found that YnZ's will make just the headlight harnesses maybe this information will help someone else. Chevy of the 40's has them also.
Office: (909) 798-1498
Fax: (909) 335-6237
YnZYesterdaysParts.com
Marv.
H Online: Content
Why would anyone pay somebody else to make a 3-wire harness?
