1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Also shows a different collar, but only for the exhaust? Some Chevy V8 exhausts have a positive rotator built into the spring retainer, resulting in needing about a 3/16" shorter exhaust valve spring. Not sure if the same assembly was used on the stovebolt engine? Jerry
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | 46er (Gerry) I tried to send you a private message but I think you're too new for you to receive one. Make a few more posts. - Rusty
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | You might want to check out vintage speed. He makes a lot of different setups with progressive linkage. He made me 3 Roch. 2 bbls that mount right onto the blower on my 292. He makes a setup that is a little manifold that will bolt to the Clifford 4 bbl. manifold.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | There are quite a few motorcycle carbs that are the right size to use 3 X 1 (make your own manifold) but remember they all use gravity feed and have very large needle & seat assemblies. For some, a smaller seat (for a fuel pump) may be bought or converted but they will run super rich as-is. | | |
