0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | I now realize that the 52 truck vs car 3 speed trannys mount differently. Will the guts from the car transmission swap over to the truck transmission?
TommyJ | | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | Areyou needing a transmission out of a truck ? If so mine will be coming available soon Im swapping over to the 5 speed from an early S-10
frankenstein Fabrications
| | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | Areyou needing a transmission out of a truck ? If so mine will be coming available soon Im swapping over to the 5 speed from an early S-10 Yes, I am needing one out of a truck. I have a 52 1/2 ton three on the tree with issues. Tommy | | |
