4 members (dt235sd, Rick Brown, Jon G, 2-Ton), 170 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#1222315 06/22/2017 6:57 PM
Is there a tag on the body that tells you what color the truck came from the factory? Or how would I know the original color, the truck has been sand blasted so there no old paint. thanks in advance.
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
Perro #1222327 06/22/2017 9:23 PM
No tag with color information on GMC and Chevrolet trucks of that era.
What year is your truck?
tclederman #1222333 06/22/2017 10:46 PM
1950
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Perro #1222369 06/23/2017 8:43 AM
Here is some GMC paint information.
Compliments of Rob English.
Perro #1222420 06/23/2017 6:04 PM
There are always some places where the color will still be lurking. Check to see what original colors were available, then try and find a hidden spot that matches. Look for places hard to sandblast, in the door hinge area, or anywhere two pieces of metal overlap. Some areas that get little wear may have just a single coat of paint over the original color, like the door frame, or in the engine compartment. I think GMC was still matching wheel color to body color in 1950. On my '48 under about three or four layers of other paint, the original color was still there. I realize that wheels have often been changed but if all yours are the same color I'll wager they're the original ones.
