0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I have a 1942 Chevrolet 1-1/2 ton truck that the head and dash lights just stop working as the truck was standing still idling. Hope someone can come up with a quick fix. Thanks!!! 1-262-392-2989 or [email protected]Marv. | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Sounds like it could be a ground wire.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Dimmer Switch! Pull the connection, clean it and reinstall. Five minute job.
| | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Seeing that both dash and head lights are out, another possibility would be a bad connection at or in the head light switch.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Check for dirty points at the thermal fuse on the back of the headlight switch. Kent | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you look at the wiring diagram, you will see that the headlight switch has a fuse. If that fuse blows it will cause the symptoms that you have described. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Found the headlight fuse bad for starters what size fuse do I need to replace it. Can't read what was on the old fuse. Thanks!!!
Marv.
| | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Was looking on the sides of the fuse I found the number on one of the ends 30amp will try a new one and let you know if that does the trick. thanks again !!!
Marv. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | The problem was the fuse but there is a short in the headlight harness will need to replace those wires. Thanks to all for your help!!!!
Marv. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Who makes just the headlight harness for a 1942 1-1/2 ton truck need both sides?????? Thanks!!!
Marv. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Before you go to the trouble to replace the harness, disconnect the dimmer switch and test it for shorts. It's not uncommon to get a short to ground inside the dimmer. Jerry
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Good point Jerry....as usual!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I am sure it is the headlight harnesses wires going though the fenders to the headlights they were touching the fender and bare. The insulation is starting to fall off after 75 years, replacing the complete wiring is not a job I am wanting to do. For now I am only going to replace what is causing the problem and I have checked out the cost of a complete harness from Jim Carter $600.00 WOW!!!! Thanks again for all your help.
Marv. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Found that YnZ's will make just the headlight harnesses maybe this information will help someone else. Chevy of the 40's has them also. Office: (909) 798-1498 Fax: (909) 335-6237 YnZYesterdaysParts.com
Marv.
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Why would anyone pay somebody else to make a 3-wire harness? Jerry
