0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | So one of the previous owners removed the foot stomp linkage and original starter, installed a solenoid starter and push button plus key switch ignition. So I can either turn the key to on and push the button or just use the key to start the engine . I've thought about "putting it back to the way it was", I've researched and found all of the components and just when I'm ready to hit the "buy" button the question that keeps coming to mind is - why did someone change it in the first place ? Were there issues with the stomp starter set-up that I should know about and that if I knew them would be thankful I have the modern set-up ? Advice from some of you experienced folks would be appreciated. Thanks in advance!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Ronnie -- some of the experts will chime in I'm sure, but I still run a stomp starter on three trucks and I see no advantage to changing. There is the coolness factor as well as the security factor -- how many people under 50 (who aren't into old vehicles) would even know what it is or how to start it? Just my opinion, but I think with a stomp starter, chicks will dig you, men will want to be you, boys will pretend to be you, deer will drop dead at the thought of you, fish will leap into your boat and dogs will instantly obey you. Trust me, your truck is WAY cooler with the stomp starter.  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I don't care how they start as long as they DO start. If I forget to leave a note with my 37 Buick (step down on foot feed) or 49 Studebaker PU (step down firmly on clutch pedal) at the tire store or any other place my phone will be ringing for help. Had a Mercedes that you pulled the shift lever back toward the steering wheel while in neutral---that one really blew their minds. 37 Fords had a push button start switch on the dash and now 80 years later the TV commercials on new cars act like it's a super new deal. The Fords also locked the steering column when the key was removed.
Evan
| | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | Despite just starting to drive my truck, I love the stomp start and it is funny to look at people's faces who have no clue what the extra peddle on the floor is!
Chris | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | I love mine also I let lots of people ( especially young ) try it ! they never ever have seen one , or a Manual Trans Just one more reason to keep it stock , street rod out of my truck ??? NO WAY
59 chevy apache fleetside
2007 dodge diesel 84 toyota 4 runner, v8,propane power
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | There is the possibility that the PO was unable to find a stomp start type strater so he changed it over to push button.
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I have to agree with John. The coolness factor and security. Also I like to keep my truck mostly the way it was built.
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I too have a mechanical stomp starter on my 39 Chevy truck, and my 29 Ford Model A. Along with electronic solenoid key/push button systems, came neutral safety switches, that prevented starting a vehicle while it is in gear. With a foot stomper, neutral and the emergency brake are a definite necessity. Four pedals, clutch, brake, gas, and starter, and only two feet. Too much for some folks to figure out. Some of my farm tractors with manual transmissions have a push button start that won't function unless the tractor is in neutral. My 72 Chevy Nova wouldn't start unless I had the clutch pedal pushed down to prevent it from starting in gear.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Viva the stomp starter LOL. I took the 49 to one of those oil change shops for it's 1st 3k oil change after I got it running mainly so I could get the tranny and rearend checked and topped off . I took my own 15w40 oil so they knocked $10 off the price. They were all younguns and were all over it. One of them jumped in it to start it up and he couldn't figure it out. Another came over to help and they both searched high and low for the starter button. After a good laugh I pointed out the stomp starter pedal. Afterwards I let all 4 of them shut it down then restart it as none of them had ever operated a stomp starter.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Afterwards I let all 4 of them shut it down then restart it as none of them had ever operated a stomp starter. That is exactly how to handle it. ...I think with a stomp starter, chicks will dig you, men will want to be you, boys will pretend to be you, deer will drop dead at the thought of you, fish will leap into your boat and dogs will instantly obey you. Trust me, your truck is WAY cooler with the stomp starter.  John This is the new correct answer to this situation. Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Friend had me get his 1940 Chevy truck running after setting for quite some years. He was having an auction and wanted to sell it. It ran great. During the auction the auctioneer leaped in the cab to show the folks how well it ran. His comment was it must have a dead battery, it isn't turning over with the key. My friends son, at the auction came up to me and asked me about the truck, told him it runs great. He got that truck for $700. At the close of the bidding on the truck I jumped in the cab, turned on the ignition, hit the foot stomper, and the engine roared to life. Auctioneer was not a happy camper.
Rick
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | There's people out there that you could give them the key to our trucks, and they still couldn't steal them. ;-)
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Ronnie -- some of the experts will chime in I'm sure, but I still run a stomp starter on three trucks and I see no advantage to changing. There is the coolness factor as well as the security factor -- how many people under 50 (who aren't into old vehicles) would even know what it is or how to start it? Just my opinion, but I think with a stomp starter, chicks will dig you, men will want to be you, boys will pretend to be you, deer will drop dead at the thought of you, fish will leap into your boat and dogs will instantly obey you. Trust me, your truck is WAY cooler with the stomp starter.  John OK, you fella's got me convinced that I should put it back to the way it was. Thanks to each of you for your comments and John. you are a "word-smith" of the highest order, you put a big smile on my face just reading your opinion.
