0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Today I fired my engine up for the first time! Seems to have a nice idle but I noticed I'm dripping fuel at the fittings in 2 places, the fittings that connect my fuel line to the Pump & Carb. I have new Stainless Steel fuel lines purchased from Inline Tube. The website says the lines are 5/16, I'm guessing that refers to the line itself and not the Male Connectors. Those to my eye appear to be 7/8. Anyway, I have the original brass fittings on my truck that step down the size to what appears to be 5/8?? These connect to the pump which I purchased at BowtieBits.com and carb which is a Carter YF. So I'm guessing the new fuel lines don't like my old fittings (they are almost 70 yrs old now) Does anyone know where I could buy these Brass Fittings, and can you point me to the correct size, it seems the fuel line male thread is 7/8 and needs to step down to about 5/8, but alas hoping someone knows what the exact inlet (female) size is on the Fuel Pumps and Carter YF Carbs. Thanks! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Do you have a NAPA nearby? They usually carry an assortment of brass fuel fittings. Take yours off and match them to some new ones.ðŸ›
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | Try backing the line nut off and applying some silicone grease to the back of the taper and the threads of the line nut. Then while holding the brass nipple, really tighten down the lines. Stainless steel takes more effort to seal then the softer steel/hybrid lines do. The grease will keep the stainless from seizing.
Joe | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | You might want to check with the supplier of the fuel lines.
Normal fittings are 45 degree. Fittings for stainless are 37 degrees. They are not compatible.
Generally the Carter YF carbs have a female 1/8 pipe.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Whenever I deal with new stainless lines (specifically from Inline), I make sure that the old fittings are spotlessly clean and not galled. I then tighten them and loosen them repeatedly. If you pay attention during this process, you will observe the gradual progression of the nut turning further as you go. This occurs without actually increasing the amount of torque being applied on each successive tightening sequence. What you are observing is the stainless steel flare becoming form-fitted to the brass fitting. If you try to tighten these lines in only one gorilla-like step, you risk galling of the stainless steel flare. Stainless steel is notorious for galling. Carl
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Besides following the procedure described by Carl, I also use stainless-steel-fitting grease (anti-seize compound). | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Tim/Carl, thanks for this info. On the Stainless steel line, do I apply some of the anti-seize compound on the inside face of the trumpet head steel line or around the outside collar/neck of the steel line that is inside the nut, or do both? I will try your advice this weekend. Also, not sure if it is overkill but i went ahead and ordered a new set of fittings from Jim Carter's Old Chevy Trucks. After looking at my original 1948 fittings more closely, they don't have a smooth mating surface/face for the trumpet head of the stainless steel fuel line to press up against. I tried soaking in soap and water for days, tooth brush,etc...but there is an old layer of dark, dirty brass patination inside each one.
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | OK, don't laugh, but get a packet of hot sauce from Taco Bell and squirt it inside of the brass fitting, then rinse it off after 5-10 minutes . If it is just caked with tarnish deposits, the hot sauce should clean it off just like it works on copper pennies.
| | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Thanks Carl, I'll give it a try, won't throw anything away. But at the same time, hoping the new ones I ordered will do the trick with the anti seize. | | |
